6509 with two 720 supervisor engine
Jun 6th, 2007
I'm having a problem with standby supervisor engine. It keeps rebooting itself. It boots fine and goes to standby mode. And, reboots after about 5 minutes. Let me know what kind of information you need from me. I will try to post it on here.
Thanks.
Peter
peterhkim Wed, 06/06/2007 - 06:25
The following is the capture from standby 720.
thanks.
SLOT0:00:07:34: %DUMPER-3-PROCINFO: pid = 16408: (sbin/ios-base), terminated due to signal SIGQUIT, Quit (Signal from user)
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: zero at v0 v1
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R0 00000000 7A9E1194 00000004 01000000
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: a0 a1 a2 a3
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R4 00FDDCD8 00FDDCE0 00000000 00FDDD70
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: t0 t1 t2 t3
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R8 FFFFFFF8 FFFAFFFF 00FDDF3C 00FDDF38
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: t4 t5 t6 t7
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R12 00FDDF34 00FDDF30 00FDDF2C 00FDDF28
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: s0 s1 s2 s3
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R16 00FDDCD8 00FDDCE0 00000004 00FDDE28
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: s4 s5 s6 s7
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R20 00FDDD78 00000000 00000000 00000008
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: t8 t9 k0 k1
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R24 00FDDF94 7222CF38 00000000 00000000
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: gp sp s8 ra
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R28 78208F20 00FDDC88 00FDDD28 722103C0
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: sr lo hi bad
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R32 1000FC73 00000000 00000000 7B8C8208
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: cause pc epc
SLOT0:00:07:34: %DUMPER-3-REGISTERS_INFO: 16408: R36 00800020 7222CF48 00000000
SLOT0:00:07:34: %DUMPER-3-TRACE_BACK_INFO: 16408: (libc.so+0x2EF48) (libc.so+0x123C0) (libc.so+0x44178) (libc.so+0x4478C) (libc.so+0x7095C) (s72033_rp-advipservicesk9_wan-25-dso-b.so+0xABAD0) (s72033_rp-advipservicesk9_wan-12-dso-b.so+0x90A64) (libc.so+0x127AC)
SLOT0:00:07:38: %DUMPER-6-BAD_PATH: 16408: Choice 1 either not configured or bad path. Trying next choice.
SLOT0:00:07:38: %DUMPER-6-BAD_PATH: 16408: Choice 2 either not configured or bad path. Trying next choice.
SLOT0:00:07:38: %DUMPER-6-BAD_PATH: 16408: Choice 3 either not configured or bad path. Trying next choice.
SLOT0:00:07:38: %DUMPER-3-DUMP_FAILURE: 16408: Core dump failed: Could not create core
SLOT0:00:07:39: %DUMPER-3-CRASHINFO_BAD_PATH: 16408: Crashinfo file creation for the path bootflash:/crashinfo_ios-base-20070606-131727 failed.
SLOT0:00:07:39: %SYSMGR-3-ABNORMTERM: ios-base:1 (jid 75) abnormally terminated, restarted disabled
SLOT0:00:07:39: %SYSMGR-6-ERROR_EOK: ios-base:1 (jid 75) mandatory process exited, rebooting
System Bo otstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Autoboot executing command: "boot bootdisk:"
Initializing ATA monitor library...
string is bootdisk:s72033-advipservicesk9_wan-vz.122-18.SXF7.bin
Loading image, please wait ...
running startup....
bootflash: bf_io_devctl: DEVCTL error 19
Image text-base: 0x01020150, data-base: 0x01021000
Created ION FileSystem for disk0, disk1
00:00:30: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:30: %PFREDUN-6-STANDBY: Initializing as STANDBY processor
00:00:32: %OIR-SP-STDBY-6-CONSOLE: Changing console ownership to route processor
00:01:03: curr is 0x0
00:01:03: RP: Currently running ROMMON from S (Gold) region
00:01:56: %SYS-STDBY-5-RESTART: System restarted --
HSEswDMZ1-sdby>
Amit Singh Wed, 06/06/2007 - 06:46
How frequent does it boot. Immediately or after some time. If it boots after a while, would be able to take an output of " sh diagn event " from it and paste it here.
-amit singh
peterhkim Wed, 06/06/2007 - 06:58
it reboots every about 3 to 4 minutes. I can try to get "sh diagn event" and post it here.
ivillagomez Wed, 06/06/2007 - 10:53
Have you tried to running diagnostics on the supervisor, if i remember correctly as of version 12.2(14) you can run diagnostics on the fly.
(conf)# diagnostic ondemand ?
peterhkim Thu, 06/07/2007 - 06:25
this is "show diagn event" from primary 720.
06/07 00:17:39.020 E [5] Minor Error Detected
06/07 00:27:13.036 I [5] Diagnostics Passed
06/07 00:28:50.812 E [5] Minor Error Detected
06/07 00:33:21.220 E [9] TestSynchedFabChannel Failed
06/07 00:38:24.911 I [5] Diagnostics Passed
06/07 00:40:02.779 E [5] Minor Error Detected
06/07 00:49:35.599 I [5] Diagnostics Passed
06/07 00:51:13.399 E [5] Minor Error Detected
06/07 01:00:46.183 I [5] Diagnostics Passed
06/07 01:02:23.747 E [5] Minor Error Detected
06/07 01:11:57.963 I [5] Diagnostics Passed
06/07 01:13:35.827 E [5] Minor Error Detected
06/07 01:23:10.067 I [5] Diagnostics Passed
06/07 01:24:47.883 E [5] Minor Error Detected
06/07 01:34:19.727 I [5] Diagnostics Passed
06/07 01:35:57.743 E [5] Minor Error Detected
06/07 01:40:27.979 E [9] TestSynchedFabChannel Failed
06/07 01:45:31.350 I [5] Diagnostics Passed
06/07 01:47:09.390 E [5] Minor Error Detected
06/07 01:56:43.078 I [5] Diagnostics Passed
06/07 01:58:20.702 E [5] Minor Error Detected
06/07 02:07:53.362 I [5] Diagnostics Passed
--More-- 06/07 02:09:31.298 E [5] Minor Error Detected
06/07 02:19:07.354 I [5] Diagnostics Passed
06/07 02:20:45.202 E [5] Minor Error Detected
06/07 02:30:17.366 I [5] Diagnostics Passed
06/07 02:31:54.970 E [5] Minor Error Detected
06/07 02:41:29.686 I [5] Diagnostics Passed
06/07 02:43:07.434 E [5] Minor Error Detected
06/07 02:52:39.881 I [5] Diagnostics Passed
06/07 02:54:18.085 E [5] Minor Error Detected
06/07 03:03:51.037 I [5] Diagnostics Passed
06/07 03:05:29.185 E [5] Minor Error Detected
06/07 03:15:02.945 I [5] Diagnostics Passed
06/07 03:16:40.773 E [5] Minor Error Detected
06/07 03:26:13.653 I [5] Diagnostics Passed
06/07 03:27:51.741 E [5] Minor Error Detected
06/07 03:37:26.557 I [5] Diagnostics Passed
06/07 03:39:04.277 E [5] Minor Error Detected
06/07 03:48:37.657 I [5] Diagnostics Passed
06/07 03:50:15.681 E [5] Minor Error Detected
06/07 03:59:48.500 I [5] Diagnostics Passed
06/07 04:01:26.308 E [5] Minor Error Detected
06/07 04:10:59.508 I [5] Diagnostics Passed
06/07 04:12:38.700 E [5] Minor Error Detected
--More-- 06/07 04:27:08.628 I [5] Diagnostics Passed
06/07 04:28:46.512 E [5] Minor Error Detected
06/07 04:38:16.404 E [9] TestSynchedFabChannel Failed
06/07 04:38:19.276 I [5] Diagnostics Passed
06/07 04:39:57.052 E [5] Minor Error Detected
06/07 04:49:31.272 I [5] Diagnostics Passed
06/07 04:51:09.052 E [5] Minor Error Detected
06/07 05:00:45.524 I [5] Diagnostics Passed
06/07 05:02:23.416 E [5] Minor Error Detected
06/07 05:11:56.271 I [5] Diagnostics Passed
06/07 05:13:34.351 E [5] Minor Error Detected
06/07 05:23:07.691 I [5] Diagnostics Passed
06/07 05:24:45.527 E [5] Minor Error Detected
06/07 05:34:18.351 I [5] Diagnostics Passed
06/07 05:35:56.331 E [5] Minor Error Detected
