VTP question
Jun 6th, 2007
Hi, Guys.
Please advice. If the situation is, that I have several switches using VTP. I am connected to the switch that is in client vtp mode, how can I know who from the switches in the LAN is the VTP server ?
pciaccio Wed, 06/06/2007 - 05:47
  • Silver, 250 points or more
Within the switch type the command SHOW VTP DOMAIN. This tells you the Updater ID IP address. This is the unit that is the server and passing the VTP updates to you...Good Luck..Please rate...
srue Wed, 06/06/2007 - 06:10
  • Blue, 1500 points or more
3550-sw#sh vtp status
VTP Version : 2
Configuration Revision : 154
Maximum VLANs supported locally : 1005
Number of existing VLANs : 23
VTP Operating Mode : Client
VTP Domain Name : VTPDOMAIN
VTP Pruning Mode : Enabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x5E 0x4B 0xFC 0xC1 0x3E 0xF3 0xBB 0xB6
Configuration last modified by 192.168.1.2 at 4-26-07 14:46:18
glengregory Wed, 06/06/2007 - 20:17
What if no IP in configured in the switches?
Glen
srue Thu, 06/07/2007 - 05:27
is that how your network is configured, or are you just theorizing?
ariela Sat, 06/09/2007 - 02:53
you'll have something like that:
VTP Version : 2
Configuration last modified by 0.0.0.0 at 4-26-07 14:46:18
So, the best thing, if you don't have a topology design of your network, is to use the CDP to make a discovery step-by-step, till find the VTP server.
That's what we do during a Customer Network Quality Assurance & Health Check.
Andrea
