Flush messages from deleted Items folder
Jun 6th, 2007
I set "Keep deleted items" to (1) one day. I activated the "Flush messages from deleted item folder" and scheduled it to run at 1:00 a.m. daily; I think I activated the script correctly - set the password - selected Apply and then OK - shows that it will run the next day at 1:00 a.m.; message store agents have been granted access. Do not permanently delete mailboxes...... is unchecked. But it does not seem to be running the script - the deleted messages are not flushing. I can perform a "Run Now" and the messages will flush. I must have missed something. Any suggestions???
See attachments for entire history.
espereir Sun, 06/10/2007 - 12:57
  • Silver, 250 points or more
Hello Mary,
This normally happens when you have entered a wrong password for this job or an user account that does not have enough rights on Exchange (should be ExAdmin at least), Please verify the password or try to use the UnityMsgStore account instead.
Hope this helps!!!
maryclegg Mon, 06/11/2007 - 02:49
You are absolutely correct about the password. Thanks!!
