06-06-2007 06:55 AM - edited 03-05-2019 04:31 PM
Hello all,
I am trying to see where I can find the last input date/time for a given switch port on a CatOS switch. I know on a IOS switch it's "sh int <int_name>" and look at the "Last input" field, but how does one do this in CatOS?
Will
06-06-2007 07:02 AM
Try show Logging buffer.
If you want to see which was the last used port you will see the message that port number x/yy is up
06-06-2007 07:46 AM
sho port status
06-06-2007 07:59 AM
Neither of these command yield the needed info...
switch> (enable) sh log
Network Management Processor (ACTIVE NMP) Log:
Reset count: 16
Re-boot History: Mar 31 2007 13:45:16 0, Mar 06 2007 07:22:00 0
Sep 30 2006 12:51:33 0, Sep 20 2003 17:18:40 0
Sep 06 2003 16:42:22 0, Jul 19 2003 11:11:12 0
Nov 29 2001 14:26:34 0, Nov 29 2001 13:37:40 0
Nov 29 2001 13:27:47 0, Nov 29 2001 13:18:53 0
Bootrom Checksum Failures: 0 UART Failures: 0
Flash Checksum Failures: 0 Flash Program Failures: 0
Power Supply 1 Failures: 12 Power Supply 2 Failures: 17
DRAM Failures: 0
Exceptions: 0
Loaded NMP version: 5.5(11)
Reload same NMP version count: 6
Last software reset by user: 11/29/2001,14:24:38
MCP Exceptions/Hang: 0
Heap Memory Log:
Corrupted Block = none
NVRAM log:
01. 4/18/2001,22:00:15: convertCiscoMIB:PreSac(0) checksum failed: 0x0(0x4C5C)
02. 11/29/2001,14:26:38: supVersion:Nmp version 5.5(11)
Module 2 Log:
Reset Count: 18
Reset History: Sat Mar 31 2007, 13:45:36
Tue Mar 6 2007, 07:22:20
Sat Sep 30 2006, 12:51:53
Sun Apr 18 2004, 01:39:44
Module 3 Log:
Reset Count: 18
Reset History: Sat Mar 31 2007, 13:45:33
Tue Mar 6 2007, 07:22:18
Sat Sep 30 2006, 12:51:51
Sun Apr 18 2004, 01:39:47
Module 4 Log:
Reset Count: 18
Sun Apr 18 2004, 01:39:45
Module 5 Log:
Reset Count: 18
Tue Mar 6 2007, 07:22:17
Sat Sep 30 2006, 12:51:50
Sun Apr 18 2004, 01:39:46
Module 6 Log:
Reset Count: 18
Reset History: Sat Mar 31 2007, 13:45:35
Tue Mar 6 2007, 07:22:19
switch> (enable) sh port status 2/3
Port Name Status Vlan Level Duplex Speed Type
2/3 XXXXXXXXXXX notconnect 103 normal auto auto 10/100BaseTX
Any other ideas?
06-06-2007 08:24 AM
There is no function that will tell you that on a catos box that I know of .
