MDS 9216i Problem
Jun 6th, 2007
  • Silver, 250 points or more
Hello All,
I am testing a MDS 9216i. I have never touched one of these boxes before so this is my first time. I grabbed 2 "notched" CAB-7k-AC power cables and im using my stadard Cisco Console setup. I powered up the box and the two power's are showing green ok led's and the Fan Status led shows green ok also. However I get no console output and the status led's on the "daughter card" and on the "module" are both red :(
Can anyone direct me as to what I am doing wrong? or is this just a broken unit?
Thanks in advance
Scott
colin.mcnamara Wed, 06/06/2007 - 11:43
  • Bronze, 100 points or more
Can you verify your console settings are
9600
8 n 1
with no flow control ?
If that is correct, then I would try re-seating your modules, and then RMA.
--Colin
sevans1979 Wed, 06/06/2007 - 12:13
Yes sir, those are my console settings. I will try the re-seating of the modules.
stephen2615 Thu, 06/07/2007 - 01:35
I don't know why you don't get any console access but if this 9216i has a second gen card in it such as 24 or 48 port card and the SAN-OS is below 3.x, you will get nasty red lights. I had a brand new 9216i delivered with the 48 port card and the switch was quite upset with it. I finally figured out the issue and upgraded to 3.x and all was ok. No more red lights.
Use a laptop instead of a dumb terminal if you can as I never could get my Wyse 60 to work on the switches no matter what setting I tried.
HTH!!
Stephen
Trending Topics: Storage Networking
