What is the default PIX OS version on PIX 501?
Jun 6th, 2007
I just purchased a used PIX 501 Firewall and need to know what OS version it has by default?
Data Sheet
hoogen_82 Wed, 06/06/2007 - 08:58
Well you could enter the show version command to know the OS version of the PIX.
If you are asking if what comes by default from Cisco, it depends on the Software you order. If you are having a 10 or a 50 user license you need to run minimum of 6.3.
Hoogen
mwall1 Wed, 06/06/2007 - 12:22
There's no default if you're buying a used PIX. It probably has 6.something on there unless it's REALLY old and the prior owner didn't upgrade it.
If you're asking about user licenses, I would say the default is 10. 50 and then unlimited are a separate costs. HTH
