Jon Marshall Wed, 06/06/2007 - 08:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chances are you will be running a 6.x version of the software as pix 501 does not support version 7.x
Attached is a link to the pix config guide for 6.3 which should get you started.
There is a graphical interface for the pix called PDM - how to set this up will be covered in config guide.
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/config.html
Jon
