CSC Warning message at startup, Is this normal?
Jun 6th, 2007
During the bootup, I get a series of
...WARNING: CSC can ONLY scan TCP traffic that is destined to port 80 (HTTP), 25 (SMTP), 110 (POP3), or 21 (FTP) when configured. Any other type of traffic, ev
en if configured, will not be scanned.
*** Output from config line 387, " csc fail-open")
One for each port. I know the CSc fail-open is to pass the traffic if csc fails, but what about the rest of the message. ? Normal?
hoogen_82 Wed, 06/06/2007 - 09:06
  • Silver, 250 points or more
Yes its normal. Its just informing you that CSC-SSM module can scan only scan the specified traffic.
If any other traffic like https or if you are looking at scanning tftp traffic or some netbios traffic it won't be scanned by the csc module.
Your config for diverting the traffic through the CSC would look like:
access-list csc extended permit tcp any any eq ftp
access-list csc extended permit tcp any any eq www
access-list csc extended permit tcp any any eq https
access-list csc extended permit tcp any any eq pop3
class-map cscmap
match access-list csc
policy-map cscpolicy
class cscmap
csc fail-open
service-policy cscpolicy interface outside
service-policy cscpolicy interface inside
-Hoogen
Do rate if this post helps :)
tahequivoice Wed, 06/06/2007 - 09:38
This one looks a bit different, it doesnt appear to use an ACL.
class-map FTP
match port tcp eq ftp
class-map http
match port tcp eq www
class-map SMTP
match port tcp eq smtp
class-map inspection_default
match default-inspection-traffic
class-map POP3
match port tcp eq pop3
policy-map inside-policy
class http
csc fail-open
class POP3
csc fail-open
class FTP
csc fail-open
class SMTP
csc fail-open
This was all done via the gui.
