MOH Fixed Audio comes thru blank...
Jun 6th, 2007
Trying to do MOH fixed audio source via Unicast. Just to 1 phone locally here (same subnet) for starters? Other music sources are playing fine.
Problem:
No music, just blank.
Here?s what I?ve done/confirmed:
-Installed Griffen iMic set to Line In
-I absolutely have confirmed I have audio going into the server (publisher). I was even able to record a wav file off of it using windows sound recorder.
-I have the audio device set to exactly the same name as the device shown in device manager on both the server and the fixed audio source.
-I?ve reset the MOH servers since then? and again, and again.
-I?ve checked the volume on both the incoming device and windows and they're pretty high... can't image I wouldn't hear anything at these levels.
Is there something simple I?m missing?
fmeetz Tue, 06/12/2007 - 08:29
  • Bronze, 100 points or more
Have you set the MOH server as Multicast?
derek.dykeman Tue, 06/12/2007 - 09:56
No, I haven't. Our WAN doesn't support multicast so I wasn't going to use it. My understanding was you don't need multicast just to get it to play on a local subnet. Correct me if I'm wrong...
Steven Pawlak Wed, 06/13/2007 - 11:40
You need to set it on the CTI ports. User and Network Hold Audio Source.
derek.dykeman Mon, 07/02/2007 - 08:32
OK, I finally opened a TAC case on this. Fix was pretty simple. In the Media Resource Group List I had to move the publisher to the top of the list. It was the one that I had the fixed audio source in. Once I rearranged those and reset devices it worked fine.
