file not found
Jun 6th, 2007
I have a cisco cme 4.1 and I have configured it aparently correctly, the problem is that I have 2 kinds of phones, 7912 and 7940, all 7912 runs correctly but 7940 doesn't register.
Normally it takes IP but in the screen appears the message "File not found"
I have tried to put a static IP address but it's the same. Why could be this?
this is the dhcp config?
Why can I debug it?
Best regards.
no ip dhcp use vrf connected
ip dhcp excluded-address
ip dhcp pool ITS
option 150 ip
ip name-server
ip name-server
Paolo Bevilacqua Wed, 06/06/2007 - 10:56
can you try a factory reset ?
Power off and press # while powering on.
When LED flashes, press 123456789*0#
Phone will look for term40.defaults.loads
Make sure you have this file and the relative .sbn files avaialable on the CCME.
I suggest to use SCCP70.8-2-1S with CCME because of a problem with directories in more recent images.
The phone will upgrade, and reset everything, after it should be able to get an address and register without problems.
fgarcia2007 Thu, 06/07/2007 - 07:58
We have tried the factory reset and the result is the same.
We would be very pleased if you explain us how to make what you suggested us in your answer. I have no idea how to use the information you gave us.
Thank you in advance for your help!
