Cisco 1720 IOS?
Jun 6th, 2007
I've solved my issue from yesterday of not being able to log into the router, I now need to copy the IOS from the router to my tftp(Laptop).
Where can I find the defualt file name for the 1720 IOS? (For example on my 2600 it's c2600-bin-mz.122-13.t1.bin)
Tyler
glen.grant Wed, 06/06/2007 - 09:45
  • Purple, 4500 points or more
On the router just do a "dir flash:
TylerCC22 Wed, 06/06/2007 - 09:56
Figured that out moments after I posted.
My new problem is this:
InternetRouter#copy flash tftp
Source filename [c1700-advsecurityk9-mz.123-3g.bin]?
Address or name of remote host []? 10.1.0.75
Destination filename [c1700-advsecurityk9-mz.123-3g.bin]?
Any ideas? Again, you'll have to forgive my ignorance, pretty new to Cisco, only been studying for 3 weeks or so.
Tyler
%Error opening tftp://10.1.0.75/c1700-advsecurityk9-mz.123-3g.bin (Timed out)
Amit Singh Wed, 06/06/2007 - 09:59
  • Cisco Employee,
Tyler,
Can you ping your TFTP server from your router or vice-versa. Make sure that your TFTP service is running the laptop.
-amit singh
Amit Singh Wed, 06/06/2007 - 10:13
  • Cisco Employee,
Is TFTP server running on your laptop. Can you try re-lauching it on your system.
-amit singh
Richard Burts Wed, 06/06/2007 - 10:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tyler
Amit made the suggestion that we all would start with which is to verify IP connectivity. If that is not the problem then I have a couple of other suggestions:
- make sure that the address given is the correct address for the TFTP server.
- make sure that the TFTP service is running on the server.
- depending on the platform and the TFTP implementation it may be necessary for the file name to exist and to have remote write permissions. What platform is the TFTP running on? does the file name that you are using exist in the TFTP directory? does it have the right permissions?
Rick
