Switch Not Usable
Jun 6th, 2007
I am having some problems with a switch that i have. It happened after a power outage but the switch is plugged into a UPS. i have pasted the info below.
Restricted Rights
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C3750 Software (C3750-I9-M), Version 12.
2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 03-Feb-04 09:20 by yenanh
Image text-base: 0x00003000, data-base: 0x007C887C
Initializing flashfs...
flashfs[1]: 80 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 6479872
flashfs[1]: Bytes available: 9519104
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Failed
POST: inline power controller test failed
driver class subsystem initialization failed
cisco WS-C3750-48P (PowerPC405) processor (revision B0) with 118776K/12288K byte
s of memory.
Processor board ID CAT0826R08M
Last reset from power-on
The password-recovery mechanism is enabled.
!!! WARNING: The switch is not usable !!!
Unable to create l2trace server process, socket_open() failed
Press RETURN to get started!
Amit Singh Wed, 06/06/2007 - 10:19
  • Cisco Employee,
Its a hardware failure on the switch. The power on self test has failed the Inline power controller test. This inline power controller hardware has failed.
Please open a TAC case and request an RMA for the same.
HTH,Please rate if it does.
-amit singh
