06-06-2007 11:23 AM - edited 03-05-2019 04:32 PM
hi guys, i have a very simple scenario but its not working, see i have a router wid fa0/0 connected to a switch, my pc is also connected to that switch. these are my configs for router
int fas0/0
ipv6 enable
no shur
then in global config i typed ipv6 unicast-routing.
now when i run show ipv6 int brief i can see fas0/0 link local address
now i install ipv6 on xp on my pc.
when i do ipconfig i can see my link local address but i dont see my default gateway :( :( :(, why my pc is not discovering my router as its default gateway ??? wat i have to do to add default-gateway to pc ??? plz dont take me wrong but dont give me advises to reinstall coz i have done it, plz tell me wat am i missing or wat should i do plz tell me
thanks in advance
06-06-2007 12:14 PM
I think enabling IPv6 will assign only link local address... not sure but i think its not give configuration for the default route... so you can have communication between two devices on the same link but not out side that...
regards
Devang
06-06-2007 12:22 PM
thanks for reply but i didnt helped me much :( plz tell me some 1
06-06-2007 01:19 PM
Is the switchport on the switch in the same VLAN as the interface attched to the router?
Is IPv6 configured on the switch?
06-06-2007 01:46 PM
You have to assign a /64 prefix (either unique-local or global) to the interface for the router to send Router Advertisement (RA) messages and therefore for your PC to get a gateway.
It would help your PC to get gateway information if it only had a link-local address.
Hope this helps,
06-06-2007 04:51 PM
I have some questions to ask you:
have you configured your cisco router as a DHCP server?
if yes, have you typed the key command "default-router" to setup a default gateway on your router?
if yes, have you enable your xp pc as a DHCP client?
