AP1220B and WLC 4400
Answered Question
Jun 6th, 2007
Will Aironet AP1220B (AIR-AP1220B-A-K9) compatible with WLC4400 with an IOS upgrade? I looked up on notes and docs but couldn't figure out if that particular model is supported to run under Wireless LAN Controller. Or I just have to do an upgrade to another model?
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html
Lightweight Access Point FAQ
http://www.cisco.com/en/US/products/ps6306/products_qanda_item09186a00806a4da3.shtml
Correct Answer by Rob Huffman about 10 years 1 month ago
Hi Zwe,
You are going to need to upgrade to a different model :( Have a look;
For all Cisco IOS Software-based Aironet 1200 Series modular AP (1200/1220 Cisco IOS Software upgrade, 1210, and 1230 AP) platforms, the ability to convert the AP depends on the radio.
If the radio is IEEE 802.11g, MP21G and MP31G are supported.
If the radio is IEEE 802.11a, RM21A and RM22A are supported.
You can upgrade the 1200 Series APs with any combination of supported radios:
G only
A only
Both G and A
From this doc;
EOS/EOL for Cisco Aironet 802.11B-Based and First Gen. 802.11A-Based Prods
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_eol_notice0900aecd802ad911.html
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
Correct Answer
Rob Huffman Thu, 06/07/2007 - 07:48
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Zwe,
G only
A only
Both G and A
From this doc;
Hope this helps!
Rob
mgzwepaing Thu, 06/07/2007 - 13:10
Hi Rob,
Thanks for the reply. I guess I only have a choice of either replacing B with G/A card on all those models or getting a whole new unit with all new technologies.
Have a good one.
Zwe
Trending Topics - Security & Network
