Warning message
Does pix 515 support more than one pptp vpdn group: radius and local auth?
Jun 6th, 2007
PIX 515 (ver 6.5 IOS) with pptp vpdn with Radius auth. Want to add second pptp vpdn group, but with local auth.
Here is the debug vpdn event output when I tried to connect with a local "innfinity" account:
Tnl 593 PPTP: Tunnel created; peer initiated
Tnl 593 PPTP: SCCRQ-ok -> state change wt-sccrq to estabd
Tnl/Cl 593/589 PPTP: l2x store session: tunnel id 593, session id 589, hash_ix=589
Tnl/Cl 593/589 PPTP: vacc-ok -> state change wt-vacc to estabd
Tnl 593 PPTP: StopCCRQ -> state change estabd to terminal
Tnl 593 PPTP: Destroy tunnel
innfinityTnl/Cl 593/589 PPTP: Destroying session
However, on the XP box I get Error 691: Access was denied because the username and/or password was invalid on the domain. It appears that the PIX is only using the vpdn group with Radius authentication. What are my options? I do not want to switch completely over to IPSEC vpn clients at this point since we have about 200 remote users configured for pptp.
bstremp Tue, 06/12/2007 - 10:25
PIX 6.x cannot have two (or more) vpdn groups using PPTP. The group name is there to differentiate between protocols (such as between PPTP and L2TP). If you configure more than one PPTP group, the system will always use the first one anyway.
It may possible in PIX 7.x.
