hanymanyy Wed, 06/06/2007 - 14:22
i don't know how that's why i'm asking
i'm using router 827 and ios 12.2
is it helpful?
david.bradley Thu, 06/07/2007 - 01:02
you need the firewall feature set. If you want to control what extensions are being downloaded (assuming you mean java applets for example) you need to use CBAC and that's a feature of the firewall feature set. You can also block specific URLs.
Assuming you can install the FW version try using SDM to configure the router.
mohammedmahmoud Sat, 06/09/2007 - 04:42
The logic is that simple, i'll try to simplfy 2 methods, and you can use any of them, the first method is to match what you want via NBAR (match protocol), and then to police it.
class-map match-any http
match protocol http url "*www.google.com*"
match protocol http url "*.rar*"
interface fastehternet 0/0
service-policy input drop-http
policy-map drop-http
class http
police 1000000 31250 31250 conform-action drop exceed-action drop violate-action drop
The second method method is to mark the traffic on the ingress on the Ethernet port and then deny it on the egress at the serial port:
policy-map mark-http
class http
set dscp 1
interface FastEthernet0/0
service-policy input mark-http
interface Serial1/0.1 point-to-point
ip access-group 101 in
ip access-group 101 out
access-list 103 deny ip any any dscp 1
access-list 103 permit ip any any
I hope that i've been informative, please never hesitate for further questions.
HTH, please do rate all helpful replies using the scroll box on the right,
Mohammed Mahmoud.
ariela Sat, 06/09/2007 - 05:49
Just another example:
class-map match-any DropTraffic
policy-map mark-DropTraffic
class DropTraffic
set dscp 1
service-policy input mark-DropTraffic
ip policy route-map null_policy_route
route-map null_policy_route 10
match ip dscp 1
set interface Null0
Andrea
hanymanyy Sat, 06/09/2007 - 13:26
this is the result
hanymanyy(config-cmap)#match protocol http url "*www.google.com*"
% Invalid input detected at '^' marker.
it's wrong at http
i don't know the wrong
do u?
mohammedmahmoud Sat, 06/09/2007 - 13:39
Can you please try this, and past the output:
hanymanyy(config-cmap)#match protocol ?
or
hanymanyy(config-cmap)#match p?
BR,
Mohammed Mahmoud.
hanymanyy Sun, 06/10/2007 - 10:35
sorry again
is there any acl which deny downloading some specific files? with an example
and another acl to deny some specific site?
with no tools or devices
mohammedmahmoud Sun, 06/10/2007 - 23:58
Hi Hany,
Unfortunately the answer is no, you need Cisco IOS URL Filtering or NBAR to filter specific websites or specific files, or use a web proxy as Andrea suggested, ACL can't do it.
HTH,
Mohammed Mahmoud.
