Redundant connection question
Jun 6th, 2007
Hello - We are in the process of migrating to another ISP. Currently, we have 5 data T1's that go into two different routers (2621) the primary router has 3 T1's and the secondary router has 2 T1's and the failover occurs via OSPF from the ISP whenever the primary POP is down. We have a third 2621 that I have configured to use with the new ISP. For that connection we are going to run with a Metro Ethernet circuit for the primary connectivity with a T1 for the backup connectivity. I am not having very much luck figuring out how to get the router configured to perform any sort of failover between the Ethernet interface(Metro Ethernet) and the Serial Interface (backup T1). If anyone has any suggestions or links to documents that show how to set something like that up I would appreciate it. Thanks
Overall Rating: 4 (2 ratings)
mpozorski Thu, 06/07/2007 - 07:09
Thanks for the link. I have reviewed it and that looks like what we are looking to do. I will need to upgrade the IOS on our router when I get a window so I can try to implement that. Thanks for the help.
