ASA5505 problem
Jun 6th, 2007
I have a strange problem with ASA5505.
Some times iam not able to ping the outside interface from Internet and the VPN tunnels goes down.
If i reboot the ASA box i will be able to ping the outside interface and the VPN tunnels comes up.
#sh ver
Cisco Adaptive Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(1)
Compiled on Wed 22-Nov-06 14:16 by builders
System image file is "disk0:/asa722-k8.bin"
Config file at boot was "startup-config"
BAR-ASA5505-01 up 1 hour 24 mins
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash LHF00L47 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0 : address is 0019.0724.9ee3, irq 11
1: Ext: Ethernet0/0 : address is 0019.0724.9edb, irq 255
2: Ext: Ethernet0/1 : address is 0019.0724.9edc, irq 255
3: Ext: Ethernet0/2 : address is 0019.0724.9edd, irq 255
4: Ext: Ethernet0/3 : address is 0019.0724.9ede, irq 255
5: Ext: Ethernet0/4 : address is 0019.0724.9edf, irq 255
6: Ext: Ethernet0/5 : address is 0019.0724.9ee0, irq 255
7: Ext: Ethernet0/6 : address is 0019.0724.9ee1, irq 255
8: Ext: Ethernet0/7 : address is 0019.0724.9ee2, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
This platform has a Base license.
Serial Number: xxxx
Running Activation Key: xxx
Configuration register is 0x1
Configuration has not been modified since last system restart.
Can somebody tell me what could be the reason?
I have attached the config file.
Overall Rating: 4 (1 ratings)
ggilbert Fri, 06/08/2007 - 05:38
  • Cisco Employee,
What kind of Internet connection do you have?
When you said you cant ping from the outside, is there a next hop router that you have access to which can ping the outside IP address.
Or if you can get into the console during that time the interface is un-responsive are you able to see any kind of errors on the interface "sh interface vlan 2" & sh interface e0/0"
This should start you in the direction to troubleshoot the problem.
Gilbert
ckuriyar74 Sat, 06/09/2007 - 05:16
We do not have next hop router.
The connection is direct ethernet hand off and terminating in ASA 5505 box.
When i connect thro console i do not see any errors int interface vlan 2 & e0/0
If i reboot the ASA the connection comes back and tunnels also.
Chandru
stephen.simpson... Fri, 06/22/2007 - 17:43
I am still getting familiar with ASA or version 7.x software, but I don't see how the ACL allow_in is applied to the outside interface. Are the loss of pings and the dropping of the VPN tunnels happening at the same time? That would seem to be an ISP problem.
