06-06-2007 10:15 PM - edited 03-03-2019 05:20 PM
Hi, I am looking for detailed information on what this command does and how to use it. I have found bits and pieces here and there with google searches but nothing substantial. Does anyone know where I can get detailed information on it?
The commands I am specifically interested in are wrr-queue bandwidth and wrr-queue cos-map.
Thanks in advance.
Solved! Go to Solution.
06-07-2007 12:48 AM
this is a good point:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/scg/swqos.htm#wp1023239
in detail, about wrr-queue bandwidth:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/cr/cli3.htm#wp1971110
and about wrr-queue cos-map:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/cr/cli3.htm#wp1971185
Andrea
06-07-2007 11:24 PM
Because on 6500 device you have 2 threshold levels for the same queue:
wrr-queue cos-map 1 1 1
wrr-queue cos-map 1 2 0
queue 1 threshold 1 cos 1
queue 1 threshold 2 cos 0
for more infos:
Andrea
06-06-2007 11:06 PM
This post of mine, should help you understanding the same configs.
If you have any questions, Please revert.
HTH,Please rate if it does.
-amit singh
06-07-2007 03:42 PM
Thank you both for your help.
asingh, in regards to your post in the other conversation, that person had the following setup:
interface FastEthernet4/41
switchport
switchport access vlan 50
switchport mode access
switchport voice vlan 250
no ip address
wrr-queue cos-map 2 1 2 3 4 6 7
wrr-queue cos-map 2 2 5
mls qos trust cos
spanning-tree portfast
How/why would he have two separate cos-maps for queue 1 and queue 2 on the one interface?
06-07-2007 12:48 AM
Andrea
06-07-2007 03:42 PM
switchport
no ip address
mls qos trust cos
06-07-2007 11:24 PM
for more infos:
Andrea
06-08-2007 03:00 AM
ahh I see. Thank you for the information Andrea.
