Hardware for Metro Ethernet
Answered Question
Jun 6th, 2007
Iam installing a Metro Ethernet for my site. The service provider is giving a 6MB 100TX Ethernet service at my area. The interface will be RJ45, and they will install a media converter to convert fibre to electrical.
For a 3845, I can order an HWIC-4ESW card. But can you let me know if a VWIC-2MFT-E1/T1 card can also be used? Since this card also has a RJ45 interface?
Please suggest
Navneet
Correct Answer by Amit Singh about 9 years 8 months ago
Navneet,
No, you cannot use that module VWIC-2MFT-E1/T1 for ethernet connectivity. Its works on a different frequeny typically the E1/T1 frequency which is 120 Ohm frequency. It uses a different line coding and framing mechanism. You cannot use it for this purpose.
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
Correct Answer
Amit Singh Wed, 06/06/2007 - 22:53
Navneet,
-amit singh
navneet_78 Thu, 06/07/2007 - 00:53
Thnx for the update Amit. It helped me clear my doubt.
Cheers
Navneet
