vlan communication.
ilnaiduccna
Hi all
I have 2 switches both switches connected through port no.44 as a uplink port, the thing is I configured vlan 15 on port no.44 in 1st switch as well as vlan 17 on port no.44 in 2nd switch now both will communicate or not.
5 Replies 5
kerek
Level 4
Level 4
Yes they will communicate as both are access ports so the two switches have no clue about the vlans configured on others.
Hope it helps,
Krisztian
If they are in the same subnet they can talk to each other. Else they will have to through an L3 device
Hey naidu,
in ur question u hav mentioned twice as port # 44 on the same switch, for uplink & vlan, so lemme know clearly.
Hi anand
I've mentioned twice as port #44 that means 1 port in one switch 2 port in other switch.
K fine,
even in that case also both of will communicate each other.
below is an example
switch-A
interface fastethernet 0/1
switchport access vlan 2
switch-B
interface fastethernet 0/2
switchport access vlan2
