Help: a ip phone service doesn't work
Jun 7th, 2007
I downloaded an xml application to get speed dials from a ip services with the following code.
I configure my phone to use this ip phone service and after all screen is empty with a button called search then I press this button and an empty screen continues and after appear a button called send that when I press it screen shows me: "Host not found". I understand nothing.
Can anybody help me?. I am begining to learn cisco ip phone services but I have basic knowledge of programmming and Call Manager. I use CCM 4.1. Thanks.
<%@ Language=JavaScript%>
// Copyright ?2001 Cisco Systems Inc. All rights reserved.
// File: sd.asp
// Author: DAD
// Purpose: Provide additional speed dials via XML Services
var serverIP;
serverIP = Request.ServerVariables("LOCAL_ADDR");
var A = String(Request.QueryString("A"));
var A2 = String(Request.QueryString("A2"));
var B = String(Request.QueryString("B"));
var B2 = String(Request.QueryString("B2"));
var C = String(Request.QueryString("C"));
var C2 = String(Request.QueryString("C2"));
var D = String(Request.QueryString("D"));
var D2 = String(Request.QueryString("D2"));
var E = String(Request.QueryString("E"));
var E2 = String(Request.QueryString("E2"));
Response.Buffer = true;
Response.ContentType = "text/xml";
Response.Write("<CiscoIPPhoneDirectory>\r\n");
if (String(A) != "undefined")
Response.Write("<DirectoryEntry>\r\n");
Response.Write("<Name>" + A + "</Name>\r\n");
Response.Write("<Telephone>" + A2 + "</Telephone>\r\n");
Response.Write("</DirectoryEntry>\r\n");
if (String(B) != "undefined")
Response.Write("<Name>" + B + "</Name>\r\n");
Response.Write("<Telephone>" + B2 + "</Telephone>\r\n");
if (String(C) != "undefined")
Response.Write("<Name>" + C + "</Name>\r\n");
Response.Write("<Telephone>" + C2 + "</Telephone>\r\n");
if (String(D) != "undefined")
Response.Write("<Name>" + D + "</Name>\r\n");
Response.Write("<Telephone>" + D2 + "</Telephone>\r\n");
if (String(E) != "undefined")
Response.Write("<Name>" + E + "</Name>\r\n");
Response.Write("<Telephone>" + E2 + "</Telephone>\r\n");
Response.Write("</CiscoIPPhoneDirectory>\r\n");
Response.Flush();
// THIS SAMPLE APPLICATION AND INFORMATION IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND BY CISCO,
// EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY
// FITNESS FOR A PARTICULAR PURPOSE, NONINFRINGEMENT, SATISFACTORY QUALITY OR ARISING FROM A COURSE
// OF DEALING, LAW, USAGE, OR TRADE PRACTICE.? CISCO TAKES NO RESPONSIBILITY REGARDING ITS USAGE IN AN
// APPLICATION., THE APPLICATION IS PROVIDED AS AN EXAMPLE ONLY, THEREFORE CISCO DOES NOT MAKE ANY
// REPRESENTATIONS REGARDING ITS RELIABILITY, SERVICEABILITY, OR FUNCTION.? IN NO EVENT DOES CISCO
// WARRANT THAT THE SOFTWARE IS ERROR FREE OR THAT CUSTOMER WILL BE ABLE TO OPERATE THE SOFTWARE WITHOUT
// PROBLEMS OR INTERRUPTIONS. NOR DOES CISCO WARRANT THAT THE SOFTWARE OR ANY EQUIPMENT ON WHICH THE
// SOFTWARE IS USED WILL BE FREE OF VULNERABILITY TO INTRUSION OR ATTACK. THIS SAMPLE APPLICATION IS
// NOT SUPPORTED BY CISCO IN ANY MANNER. CISCO DOES NOT ASSUME ANY LIABILITY ARISING FROM THE USE OF THE
// APPLICATION. FURTHERMORE, IN NO EVENT SHALL CISCO OR ITS SUPPLIERS BE LIABLE FOR ANY INCIDENTAL OR
// CONSEQUENTIAL DAMAGES, LOST PROFITS, OR LOST DATA, OR ANY OTHER INDIRECT DAMAGES EVEN IF CISCO OR ITS
// SUPPLIERS HAVE BEEN INFORMED OF THE POSSIBILITY THEREOF.
