CallManager 5.1 directory URL
Jun 7th, 2007
I would like to edit "jsp" files used in CCM 5.1.1 to access "directory" pages on IP phones".
In the "Entreprises parameters", the IP address is:
http://<CCM IP address>:8080/ccmcip/xmldirectory.jsp
When I open this URL in a web browser, I can see 2 other URL's:
http://<CCM IP address>::8080/ccmcip/xmldirectoryinput.jsp for "Corporate Directory"
http://<CCM IP address>:8080/ccmpd/pdCheckLogin.do?name=undefined for "Personal Directory"
Where can I find these "jsp" files? How can I have access to "ccmcip" and "ccmpd" folders?
Thanks in advance.
Fran?ois
mchandak Thu, 06/07/2007 - 04:20
  • Gold, 750 points or more
Since CM 5.x works in Appliance mode, you dont have access to these files and you cannot modify these files either. Incase you want to run a custom directory, you would have to create a custom file and upload it to your Web Server (Not CM 5.x) and then update the URL under Enterprise Parameter or for specific phones to use the URL mentioned when querying Directory
mchandak Thu, 06/07/2007 - 04:52
When accessing this page from a IE, Hit View|Source. This is the all that would be visible. Since there is no interface available to access the CM Files (Except for TFTP and Log files).
Russell La Plante Fri, 08/31/2007 - 10:57
Any pointers to wade through cisco documentation on how to properly format the custom page. We tried using the source same source code from the original xmldirectory.jsp and it did not work.
