06-07-2007 02:41 AM - edited 03-05-2019 04:33 PM
Device is 2 x Cisco 2800 on Same site, they are working as an HRP pair, when they are powered down and powered up again, the one that is meant to be on standby does not join the HSRP.
The system image for active is c2800nm-ipbase-mz.124-3a.bin
The system image for standby is c2800nm-advipservicesk9-mz.124-4.T.bin
06-07-2007 02:47 AM
Can you please post the configuration of both of your routers? Thanks.
-John
06-07-2007 02:55 AM
These are the configs, for security reasons, I have removed the public Ip addresses.
Configuration of active
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.192
ip nat outside
duplex full
speed 100
no cdp enable
standby 190 ip x.x.x.x
standby 190 timers 1 4
standby 190 priority 110
standby 190 preempt delay minimum 3600
standby 190 track GigabitEthernet0/1 20
interface GigabitEthernet0/1
ip address x.x.x.x 255.255.255.0
ip nat inside
duplex full
speed 100
standby 128 ip x.x.x.x
standby 128 timers 1 4
standby 128 priority 110
standby 128 preempt delay minimum 3600
standby 128 track GigabitEthernet0/0 20
Configuration of Standby
ip nat outside
no ip virtual-reassembly
duplex full
speed 100
no cdp enable
standby 190 preempt
ip nat inside
duplex full
speed 100
standby 128 preempt
06-07-2007 03:03 AM
What do you usually do to make the HSRP go back to normal? What is the debug standby output?
06-07-2007 06:38 AM
After the two routers are power-cycled the "standby router" on interface Gi0/1 doesnt establish as an HSRP pair and displays as state = init
It will remain like that until I "shutdown" the interface and then "no shutdown"
After that HSRP establishes itself correctly
06-07-2007 07:06 AM
Mayamba
When the routers are power cycled and the standby router is not joining the HSRP does show cdp neighbor show the neighbor on the interface? It sounds to me like when they are power cycled that something is not initializing correctly and that the HSRP frames are not getting through.
Rick
06-07-2007 09:26 PM
In active and standby switch configuration you are trying to track the interface "standby 190 track GigabitEthernet0/1 20" and "standby 128 track GigabitEthernet0/0 20" of another physical router. I think it is possible to trace only the connected interface of the same device.
If you could share the debug ip standby we can trace this issue.
Uvaraj
