DDI call with secondary Dial Tone
Jun 7th, 2007
I have a PRI set up on MGCP which is working correctly with DDI to IPT phones, we also have a dial-peer pot connecting to a FXS port on the same router. The dial-peer pot is for a fax DDI number also delivered via the same PRI. The issue is that when an external caller dials the IPT DDI everything works , but when you dial the DDI for the FXS port you hear secondary Dial tone allowing you dial other numbers such as VM, internally there are no problems. The PRI dial-peer is set up correctly with direct inward ....- any idea`s- thanks
