Jun 7th, 2007
Hi all
Has anyone tried to set up a HP Server (DL380 G5 assembled according to Cisco recommendations) with more than 4GB RAM??
I tried to set it up with 6GB but Windows can not use more than 4GB. I read some articles about the 4GB Limit and how break it (/PAE Switch) but I don't know if that is supported (TAC).
Has anyone an idea?
Thanks Reto
Overall Rating: 1 (1 ratings)
espereir Sun, 06/10/2007 - 11:26
Actually, you must meet the HW requirements in order to have a fully supported server and the 4 GB restriction is W-32bit restriction not Cisco.
The problem will be if you break Windows limit and if for any reason yo start experiencing any problems, TAC will deny the support.
I think that is better to have 4 GB and TAC support instead of 6GB without it.
