password recovery
Jun 7th, 2007
I have a 7200 series router I need to do a password recovery on. When I reboot it and hit ctrl-break I still don't get into romon mode. I am using windows hyperterminal. I also tried to pull the flash out but it still boots.
Amit Singh Thu, 06/07/2007 - 05:44
  • Cisco Employee,
Please follow the link below for password recovery on the 7200 routers. You have to press " Break " within 60 seconds after the reboot.
http://www.cisco.com/en/US/products/hw/routers/ps341/products_password_recovery09186a00800942d3.shtml
Use the link below ofr standard break sequence proceducres:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
HTH,Please rate if it does.
-amit singh
6tgreene Thu, 06/07/2007 - 05:54
thanks anyway I have both of those doc's they didn't help
aungsan.moe Wed, 12/12/2007 - 08:13
Hi, I faced the same problem of password recovery on 7204 VXR with NPE-1G. I am using windows 2000 hyperteminal. I followed the procedure in the doc that I found in cisco website. it did not work. I am thinking of using another PC to try it again. Can you pls help us if you already have a solution to it.
Aung San Moe
glen.grant Wed, 12/12/2007 - 09:34
  • Purple, 4500 points or more
Get something other than hyperterm , certain versions had problems issueing a control break . Go get something like Tera Term and I bet it will work .
