Running hybrid mode with ATA flash card
Answered Question
Jun 7th, 2007
Have an ATA flash card that can not be formatted or read in slot0 of the 6509 sup2-2ge engine. Is there another card recommended for this?
Correct Answer by ankbhasi about 10 years 2 weeks ago
Hi Friend,
From release notes
With software releases 7.5(1) and later, additional Flash PC card support was added as follows:
?64-MB ATA Flash PC card (MEM-C6K-ATA-1-64M=)?Only supported on Supervisor Engine 2. The device name is disk0: and the card requires ROMMON version 7.1(1) and later releases.
?64-MB linear Flash PC card (MEM-C6K-FLC64M=)?Only supported on Supervisor Engine 1. The device name is slot0: and the card requires ROMMON software release 5.3(1) and later releases.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm#wp410962
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Thu, 06/07/2007 - 05:40
  • Cisco Employee,
Hi Friend,
From release notes
Ankur
