enabling a third interface
Answered Question
Jun 7th, 2007
question is more cosmetic I guess but I'm trying to name a third interface and I get an error stating you cannot have more than 2 named non-management interfaces on your system. My other ASAs can do this with the excpetion of this one. We are all on 7.2(2) software. Any ideas?
Correct Answer by vitripat about 10 years 3 weeks ago
Your firewall might be running in transparent mode. In this mode, you can only have 2 non-management interfaces.
ASA# show firewall
Firewall mode: Transparent
If you dont want your firewall in Transparent mode, you can change it to router mode using following command-
ASA(config)# no firewall transparent
Hope that helps.
Vibhor.
Overall Rating: 5 (1 ratings)
Correct Answer
vitripat Thu, 06/07/2007 - 09:55
  • Gold, 750 points or more
ASA# show firewall
Hope that helps.
Vibhor.
