Anonymous (not verified) Wed, 06/13/2007 - 11:02
I am not sure, you can use the ACS to restrict the access for each user or the group. The CSACS from 3.x it starts supporting this feature.
jlwomeld Mon, 07/02/2007 - 09:56
You can restrict VPNUser to a subnet, you need to create a networklist and a rules and a filter that will apply yo the group you want to restrict.
srue Mon, 07/02/2007 - 10:13
  • Blue, 1500 points or more
what about using downloadable ACL's with CS-ACS?
jlwomeld Mon, 07/02/2007 - 11:19
I set the VPN Con to use rules and filter, I auth the group through the VPN Con. This is a remote user I am doing it this way so I do not have to create an username on my network. So I am not using the ACS at all. I have doc on how I did this. just e-mail me your address.
kevinhobson2000 Mon, 07/02/2007 - 23:23
Id already figured out how to do this using group policys and vpn filters.
Thanks for the advice anyway.
Cheers
Kev
