Problem Matching QOS Citrix
Jun 7th, 2007
Hello, i cant with my current configuration to match the citrix traffic incoming (interface gi 0/0), this router is 2821. IP cef is enable. When i do the command:
sh ip nbar protocol-discovery int gi0/0 (result in the attachement). Always Citrix zero. The version of PDLM is 10.
Thanks a lot for your help.
dgahm Thu, 06/07/2007 - 08:02
  • Blue, 1500 points or more
David,
Try adding this command:
ip nbar pdlm flash:citrix.pdlm
Please rate helpful posts.
Dave
martinez.david2 Thu, 06/07/2007 - 08:24
This order has been entered. The router says me that my pdlm is more recent.
dgahm Thu, 06/07/2007 - 08:52
David,
So the PDLM is in the IOS. Your config looks correct. I have this running on 7206s, and it matches correctly on the ICA tags.
Is your Citrix implementation using port 1494 or 2598 session reliability? I do not think Citrix NBAR supports 2598, but I need to find out, because we are heading that way.
I would build an access list to check this out.
access-list 101 permit tcp any eq 1494 any
access-list 101 permit tcp any any eq 1494
access-list 101 permit tcp any eq 2598 any
access-list 101 permit tcp any any eq 2598
access-list 101 permit ip any any
Apply this inbound on your interface:
ip access-group 101 in
Then show access-list 101 and look for hits.
Dave
martinez.david2 Fri, 06/08/2007 - 05:22
I have tried to do that with acl, so I saw well that I used the port 1494 in TCP, Is there one or more commands in my configuration could prevent the match nbar.
