CSA Organization
Answered Question
Jun 7th, 2007
I am looking for some tips on how to best organize Policies, Rule Modules and Rules.
Specifically is it better to create more Policies, Rule Modules or Rules.
Correct Answer by tsteger1 about 9 years 10 months ago
Leave as much of the original configuration intact as you can and make new policies>modules>rules for your exceptions.
This will not only make it easier to manage, it will make upgrades much easier.
Upgrades will replace original configuration objects only if they have not changed.
The more that are replaced by an upgrade, the less you have to do manually.
Having all exceptions in a single policy or policies should allow you to manage them more efficiently too.
Overall Rating: 5 (2 ratings)
Correct Answer
tsteger1 Fri, 06/08/2007 - 11:28
  • Red, 2250 points or more
pmccubbin Sun, 06/10/2007 - 04:34
  • Silver, 250 points or more
Tom,
In a nut shell this is great advice. I give it a 5 rating. Keep up the good work and thanks for all your responses on this topic.
Paul
tsteger1 Mon, 06/11/2007 - 13:16
Thank you Paul, I appreciate that.
Tom
eaglesecure Tue, 06/12/2007 - 04:44
Thanks, this information will be very useful when upgrading in the future.
tsteger1 Tue, 06/12/2007 - 15:44
Glad to be of service. Good luck with it.
Tom
