Are default queue values on 6500 blade adequate?
Jun 7th, 2007
I am using a 6509 with the Ws-X6148A-GE-45AF blade as our access layer and will have an IP phone and PC plugged into each port.
I will be classifying voice traffic DSCP=46, call control as DSCP=24 and everything else DSCP=0 (all data traffic from the PC), with the following cos-dscp map:
mls qos map cos-dscp 0 8 16 24 32 46 48 54
With 'mls qos' enabled globally, will the resulting default queue bandwidth and buffer space and queue cos-map be adequate for what I need?
Here is the output of 'sh queueing int g1/1':
GHQ-6509A-AU-W271B#sh queueing int g1/1
Interface GigabitEthernet1/1 queueing strategy: Weighted Round-Robin
Port QoS is enabled
Trust state: trust DSCP
Extend trust state: not trusted [COS = 0]
Default COS is 0
Queueing Mode In Tx direction: mode-cos
Transmit queues [type = 1p3q8t]:
Queue Id Scheduling Num of thresholds
01 WRR 08
02 WRR 08
03 WRR 08
04 Priority 01
WRR bandwidth ratios: 100[queue 1] 150[queue 2] 200[queue 3]
queue-limit ratios: 50[queue 1] 20[queue 2] 15[queue 3] 15[Pri Queue]
queue tail-drop-thresholds
1 70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
2 70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
3 100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
queue random-detect-min-thresholds
1 40[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
2 40[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
3 70[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
queue random-detect-max-thresholds
WRED disabled queues:
queue thresh cos-map
1 1 0
1 2 1
1 3
1 4
1 5
1 6
1 7
1 8
2 1 2
2 2 3 4
2 3
2 4
2 5
2 6
2 7
2 8
3 1 6 7
3 2
3 3
3 4
3 5
3 6
3 7
3 8
4 1 5
The default queueing values give queue 1, which will be all the PC data traffic, 50 % of the buffer space and voice traffic 15%.
Does that mean if the interface is a 100mbs interface, and the PC is transferring say 70mbs, that when the traffic reaches over 50mbs in queue 1 packets will begin to be randomly discarded?
Also the default for the priority queue is 15%, which is 15mbs, which is far more than one phone call.
Should I increase the default queue 1 % and decrease the priority queue %, or are the default vaules OK?
It seems that once I get into tweaking and changing the default values, I'll be stepping into some really murky areas and better know what I'm doing - which at this point I don't.
