Websense
Jun 7th, 2007
sh url-server stat reports denied sites but the websense is not set to deny any url right now. What could be the problem?
sh url-server st
Global Statistics:
URLs total/allowed/denied 7549434/7549358/76
URLs allowed by cache/server 0/7549358
URLs denied by cache/server 0/76
HTTPSs total/allowed/denied 1454300/1454300/0
HTTPSs allowed by cache/server 0/1454300
HTTPSs denied by cache/server 0/0
FTPs total/allowed/denied 0/0/0
FTPs allowed by cache/server 0/0
FTPs denied by cache/server 0/0
Requests dropped 0
Server timeouts/retries 0/11
Processed rate average 60s/300s 10/17 requests/second
Denied rate average 60s/300s 0/0 requests/second
Dropped rate average 60s/300s 0/0 requests/second
Server Statistics:
10.0.3.29 UP
Vendor websense
Port 15868
Requests total/allowed/denied 9003734/9003658/76
Responses received 9003734
Response time average 60s/300s 0/0
URL Packets Sent and Received Stats:
Message Sent Received
STATUS_REQUEST 292632 292632
LOOKUP_REQUEST 9048746 9048733
LOG_REQUEST 0 NA
Errors:
RFC noncompliant GET method 4
URL buffer update failure 0
bwalchez Wed, 06/13/2007 - 11:03
Websense is a third-party filtering software that can filter HTTP requests on the basis of the following policies: destination hostname, destination IP address, keywords, and username. The software maintains a URL database of more than 20 million sites organized into more than 60 categories and subcategories.
http://cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b0e.html#wp1027188
mark.cronin Mon, 07/30/2007 - 05:00
I have a Cisco CE-565A which can support Websense version 5.5.2 if upgraded with the new Cisco ACNS Version 5.5.7
I need features that are available in Websense version 6. Is there a Cisco appliance that can support this.
I am not sure if a new Cisco product is compatible with the latest Websense 6.3.1, I will check.
rmeans Mon, 07/30/2007 - 12:55
What does your filter statement look like? Do you have the allow statement at the end? For example filter url http 0 0 0 0 allow. If you do not have the allow statement, when the firewall can not communicate with the websense server url access will be denied. I noticed you have a lot of stat counts. You may want to consider clearing the stats from config mode (clear url-server stat). Monitor the any increases in the deny counts to see if any traffic is actively being dropped.
Tshi M Mon, 07/30/2007 - 13:04
url-server (inside) vendor websense host 10.0.x.x timeout 30 protocol TCP version 4 connections 15
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
filter https 443 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
url-block block 128
url-block url-size 4
url-block url-mempool 100
url-cache src-dst 100
rmeans Tue, 07/31/2007 - 04:48
Thank you for the information. I do not see anything obvious. Do you have the syslog messages indicating the URLs were denied? I was reading the command reference. When configuring the firewall add the url-server first followed by the filter commands. I am not sure of the impact if you reverse the order. Maybe traffic is denied (who knows). Finally, what version of OS are you running. I know that early 7.x code had a number of issues with Websense. Have you looked at the bug tool kit to see if your OS version has any related Websense bugs?
