ankbhasi Thu, 06/07/2007 - 07:05
  • Cisco Employee,
Hi Friend,
By default all switches layer 2 ports are in dynamic desirable mode so if you do not manually configure it as "switchport mode access" then it will try to from a trunk with remote port which generating DTP frames.
It is always recommended that if you do not want the port to form a trunk manually configure it as an access port.
Ankur
*Pls rate all helpfull post
jgreggain Fri, 06/08/2007 - 08:00
We also enter the command "switchport nonegotiate" on the interface, just to make sure it doesn't try to form a trunk port.
Jeff
srue Fri, 06/08/2007 - 10:50
  • Blue, 1500 points or more
switchport mode access - this puts the interface in access mode only, and it will still generate DTP's to let the other side know.
switchport nonegotiate - whether in trunking or access mode, causes the switch not to generate DTP's.
