ip address resolution
Jun 7th, 2007
I had configured my 4006 switch with ip address but when i ping with -a to that ip address it's resolving to the hostname which is assigned to the system. But i checked with the system ip address which is using Is there any command to resolve the ip address to host in switch? Please help me to disable this.
royalblues Fri, 06/08/2007 - 03:15
There is nothing to be done on the switch for that. Basically it happens when the router/switch is assigned an IP which had been earlier assigned to any system.
You need to clear this entry in your DNS to resolve it, mostly a stale entry in the reverse lookup.
HTH, rate if it does
