06-07-2007 07:50 AM - edited 03-18-2019 07:26 PM
I've deployed a Unity Connection 1.2 system, using SMTP notifications with the embedded PCA link.
The link contains a URL using the netbios name of the CUC server. This resolves correctly and sends the browser to the login page, however it returns a 500 HTTP error when a login is attempted.
If we use the IP address or FQDN in the URL in place of the NETBIOS name, it works just fine.
We'd like to change the URL embedded in the email - is this possible?
Aaron
06-07-2007 07:06 PM
Hi Aaron,
Do you know how to update the SMTP email addresses for ALL the users with CSV files? I tried to do a 'trial' export but none of the email fields got updated.
Look forward to hear from you.
Kind Regards,
Hunt
06-08-2007 12:24 AM
Hi Hunt
I've not tried it to be honest... but I'd check that you're trying to update the SMTP notification address, not the SMTP address of the user as on the user's general info page.
Aaron
