Block 59 checksum failed
Jun 7th, 2007
Cisco Catalyst 2498G
It was given to me to re-configure. Apparently it was in a wiring closet that got hit by lightning. seems to work ok after I did some work on it, but this error shows up in the logs
6/7/2007,06:24:52: check_block_and_log:Block 59 checksum failed: 0x55EE(0x55
anything I need to be worried about? Every port seems to test out fine and I can navigate in the Console just fine.
htarra Fri, 06/15/2007 - 10:20
It is NVRAM log error message.( check_block_and_log:Block 0 checksum failed).
A determination is then made as to whether or not a checksum was required to ascertain the value of any digit within the POSTNET barcode, as shown in block 59.
