Invalid device id: Slot0
barnettmark
Can someone please help, I am wanting to configure an 877 Router but when powering on I get the following Message;
Invalid device ID: Slot0
Then the router proceeds to reboot I have tried to boot into ROMMON but without any joy. Also unable to type anything in IOS as it just goes to that point and reboots.
Has anyone got any suggestions to get around this Problem.
Thanks Mark
paolo bevilacqua
Hi Mark,
Please try sending some breaks from your terminal program while the router boots.
You should be able to enter rommon, at that point please do "set" to check what environment variable are configured that are possibly causing the problem.
