Haow To Verify IPSEC VPN Throughput
I have a need to prove the throughput I'm getting through a recently installed VPN between an ASA5520 (failover pair) connected via a 34Mb internet pipe and an ASA5510 (single) connected to the internet via a 10Mb internet pipe. The VPN is all working well using AES-256 but users at the remote location (5510) are expressing concern over slowness.
What sort of speed 'should' I be seeing through the VPN ??
and what is the best method of testing/proving the connection ?
Many thanks in advance.
Stu
srue Thu, 06/07/2007 - 12:15
  • Blue, 1500 points or more
if you have a cisco security manager license, you could use Performance monitor to do this i think.
Are these two endpoints connected to the same ISP?
ciscors Wed, 02/27/2008 - 18:07
I recently encountered a similar problem with AES 256 and downgraded to AES 128 and it got rid of the problem.
Let me know if this helps you
