06-07-2007 09:33 AM - edited 03-05-2019 04:34 PM
I have replication going from 1 device to another. The path is Device --> Switch --> Router --> Switch --> Device.
On the return, the device is sending: Device -->Switch --> Switch --> Device.
How does this affect traffic? Does it slow it down because its going a different way than what it was recieved?
06-07-2007 09:38 AM
Is device 1 on a different vlan than device 2 and if so if one of the Switches a layer 3 switch.
Jon
06-07-2007 10:55 AM
Different VLANS, but switches are 3750
06-07-2007 09:42 AM
Rob,
If the traffic is indeed coming the same way back then you would definately see some performance slow down as it will be asymmetric routing process. this will slow down the traffic process a little bit as the return traffic is not taking the same patch to the client.
http://danno.appliedi.net/drupal/?q=node/101
HTH,Please rate if it does.
-amit singh
06-07-2007 11:40 AM
amit, do you mean if the traffic is taking a differnet way back?
