Only 1 way traffic on a 2 way VPN
Jun 7th, 2007
Hello, I am having trouble getting a Lan 2 Lan vpn to allow 2 way traffic. I am able to bring up the VPN and send/recieve from my end, the remote end can sometimes bring up the vpn, but can't seem to reach my inside network no matter what.
Any ideas where I may have misconfigured this?
I am using ASA5510
Remote site = sidewinder
acomiskey Thu, 06/07/2007 - 10:13
  • Green, 3000 points or more
Check ASA config for
version 7.0,7.1
isakmp nat-traversal
version 7.2
crypto isakmp nat-traversal
rschling22 Thu, 06/07/2007 - 10:34
I am running version 7.2 here is the output of the sh crypto command, the line you asked about is there.
ciscoasa# sh run crypto isakmp
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal 20
Anything else? how do I tell if the problem is my end or thiers?
acomiskey Thu, 06/07/2007 - 10:41
Oh, lan 2 lan tunnel, sorry.
Can you post the ASA config minus passwords etc. Also is the topology just like this, no other firewalls etc.?
your inside -- ASA -- Internet -- Sidewinder -- their inside
rschling22 Thu, 06/07/2007 - 11:09
Yes, that is the basic topology
My Inside--ASA--Internet--Sidewinder--Thier Inside
Here is a slimmed down output of my sh run. I tried to delete IP's and most of the stuff that doesn't pertain to this, if I removed too much please let me know, and I'll try to get it right.
Rob
vpn-tunnel-protocol l2tp-ipsec
group-policy DefaultRAGroup_1 internal
group-policy DefaultRAGroup_1 attributes
dns-server value A.A.A.199
Deleted
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 80 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 100 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 120 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 140 set transform-set TRANS_ESP_3DES_SHA
crypto dynamic-map outside_dyn_map 160 set transform-set ESP-3DES-SHA
crypto map outside_map 1 match address outside_cryptomap_8
crypto map outside_map 1 set peer REMOTE VPN PROBLEM IP C.C.C.193
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map 1 set phase1-mode aggressive
Deleted
crypto map outside_map interface outside
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash md5
group 2
lifetime 86400
Deleted
isakmp keepalive disable
tunnel-group REMOTE VPN PROBLEM IP C.C.C.193 type ipsec-l2l
tunnel-group REMOTE VPN PROBLEM IP C.C.C.193 ipsec-attributes
pre-shared-key *
Deleted
acomiskey Thu, 06/07/2007 - 11:29
Can you log on the ASA as they try to bring up the tunnel?
debug crypto isakmp
debug crypto ipsec
rschling22 Thu, 06/07/2007 - 11:41
Hey, good idea, why do I always forget that command.
Ok, tried it, shows nothing, had it tear down and reset the tunnel twice. no debug entries.
Bummer.
acomiskey Thu, 06/07/2007 - 11:45
debug crypto isakmp 7
debug crypto ipsec 7
rschling22 Thu, 06/07/2007 - 11:24
Heres another tidbit. I have been getting this error message whenever the remote side tries to set a connection
3 Jun 07 2007 13:21:39 713042 IKE Initiator unable to find policy: Intf outside, Src: MY-INSIDE-IP, Dst:THIER-INSIDE-IP
Hope this helps someone
acomiskey Thu, 06/07/2007 - 11:30
can you post your access-list outside_cryptomap_8?
rschling22 Thu, 06/07/2007 - 12:23
Arg, er.. good news!
the remote site finally got it fixed. seems it WAS on thier end.
thanks for all your help
Rob
