untiy ports not found
bmarlin
Just installed unity for the first time unity is up and working put callmanager keeps saying that port status not found.
I think it has something to do with css but not sure.Side note
I didn't build the callmanager.
8 Replies 8
ranpierce
Level 6
Level 6
You would need to have the CallManager voicemail ports configured. What version of CallManager do you have and I will point you in the right direction.
rlp
HI
4.1(3)sr5
I had the callmanager ports already done dy you mean unity ports?
Yes I mean the Unity ports or Voicemail Ports or even UOne ports. It all depends on what version of CallManager you are at.
Which version?
rlp
Oh sorry I got it. Looking for documentation.
This is probably the section that you will want depending on your configuration.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/ccm41u40.html#wp1772593
rlp
Thank you for info
