Voice Trunk PBX-IP-PBX
Jun 7th, 2007
Trying to replace the 2 t-1 tie lines inbetween pbx's. With a 3845 and a 2811 router useing 1 VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 in each end.
Basically got
controller T1 0/2/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1 type e&m-wink-start
ds0-group 1 timeslots 2 type e&m-wink-start
voice-port 0/2/0:0
timeouts call-disconnect 3
connection trunk 201 answer-mode
dial-peer voice 1 pots
destination-pattern 100
port 0/2/0:0
This is x48 timeslots/dial-peer's ect on both ends
I am hitting the loopback on each router with this:
dial-peer voice 50 voip
destination-pattern 2..
session target ipv4:172.31.255.1
dtmf-relay h245-signal h245-alphanumeric
ip qos dscp cs5 media
Basically the trunk comes up but the avaya pbx on each end doesnt show anything. am I missing something?
Paolo Bevilacqua Thu, 06/07/2007 - 15:30
Instead of connection trunk, you could let the router interpret the numbers from the pbx instead. You will need 48 DP pots because you are have created on voice-port per channel. You can reduce reduce this to 2 if you put 24 timeslots in the ds0-group, you would loose 1:1 mapping between PBX's timeslots, but probably doesn't matter.
madcat Mon, 06/11/2007 - 14:42
Actually I tried 1 ds0-group for each line. It didn't work as not all the lines would come up. With this config i get all the channels to come up and trunk.
okuehn Mon, 03/10/2008 - 00:56
Hi Paolo,
we need to connect two old PBX through IP (PBX_A-2821--IP--2821-PBX_B)
by reading cisco docs, actually, i would choose "connection trunk". can you please describe your proposal? what are the advantages and/or the requirements?
Paolo Bevilacqua Mon, 03/10/2008 - 08:52
Hi, as mentioned above you can use connection trunk, but a regular configuration where you received the numbers gives you more control and debug. So I suggest you configure the signalling used by the PBX and interpret the number, that interface is that ?
