I think i killed one of my controllers! HELP!!!!!
Jun 7th, 2007
I was trying to update the ios and my tftp server lost connection to the wlc and the entire controller rebooted, loading back to only a "grub>" prompt. Is there any way I can reinstall the image or something!!! Please HELP!!!!!!
justinfvoeller Thu, 06/07/2007 - 12:59
so I have to send this controller back to cisco? will they fix it or just replace it?
ericgarnel Mon, 06/11/2007 - 05:59
That is a bummer about your controller.
It is interesting that you get a grub> prompt.
Sounds like the controller OS is embedded linux
Trending Topics - Security & Network
