sh spanning-tree vlan detail
Answered Question
Jun 7th, 2007
Does anyone know in which documentation may we find the exact explications avout the output of sh spanning-tree vlan detail?
Navid
Correct Answer by royalblues about 10 years 1 month ago
What explanation are you exactly looking about?
Though the following link does not directly give explanation on the output, this points out to the direction what you need to look upon when you have problems
http://www.cisco.com/warp/public/473/170.html
HTH, rate if it does
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Fri, 06/08/2007 - 06:46
  • Green, 3000 points or more
Narayan
