WiSM & SUP720 Performance Issue
Jun 7th, 2007
  • Bronze, 100 points or more
We use WiSM 4.0.217.0 and SUP720 12.2(18) SXF5. We experience bad performance with wireless client download, for only about 70kbps. I tried with a WLC2006 connected to the same SUP720 with similar configurations with WiSM and I got 2Mbps download speed via WLC2006. Has anyone seen this issue before?
Thanks!
Zhenning
Overall Rating: 4 (1 ratings)
thomas.chen Wed, 06/13/2007 - 11:08
  • Silver, 250 points or more
There are several possible reasons that this error message is generated. From the WiSM's perspective, the most common reason is an incorrect configuration of the service port on the Supervisor Engine.
In the case of a WiSM, the service port is used solely for communication between the Supervisor 720 and the WiSM.
Complete these steps in order to get rid of this error message.
Create a new VLAN for the WiSM service ports on the Supervisor Engine that does not exist anywhere on the network.
Create a DHCP scope setup on your Supervisor 720 to assign IP addresses to the service ports of the controllers. This IP range should not start with the same octet of any interface that already exists on your network .
Note: It is recommended that you create a DHCP scope for the service port of the Catalyst WiSM. Alternatively, you can also session (session slot X process 1 or 2 ) or console directly into the WiSM and set the static IP addresses (configure the interface address service port).
Assign the WiSM service ports to this newly created VLAN with the command wism service-vlan new VLAN ID on the Supervisor Engine.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
