3560 switch issue?
Jun 7th, 2007
Hi...
I was trying to connect 2 PC to a 3560 switch which is a vtp client. The vlan database is being updated from the vtp server with no issues.
The 2 pcs to be connected are supposed to be in the management vlan, but when I move the switch ports to the management vlan the port LED remains amber, never turns green, and when I do sho vlan I see no ports under the management vlan, even I cannot find the 2 ports under any vlan.
I tried resetting the switch, shutting douwn/up the ports but no result. Could it be IOS related? Or is there any known bug.
All Help is appreciated.
sundar.palaniappan Thu, 06/07/2007 - 14:58
Do you have trunk configuration under the ports? Can you post the configuration of the ports and 'show int (int#) switchport'.
mo shea Thu, 06/07/2007 - 15:31
The trunk mode is dot1q and is set as desirable. I will post the configs once I get to the office.
In what way can the trunk affect the situation Iam facing? Just as a reminder the switch works fine and i can telnet to it from anywhere in the LAN.
sundar.palaniappan Thu, 06/07/2007 - 15:45
If these ports are connected to the PCs why do you want to trunk anyways? It appears the port is attempting to become a trunk and is failing. Moreover, 'show vlan' doesn't show a port assigned to any VLAN when the port is in trunking mode.
Try configuring the port as an access port and test.
Sundar
