It is disabled because it is the default CH, anyhow, you can create a new rule and move it over the default rule, or you can make the Default Opening Greeting to transfer the calls to your handler.
I believe that the best option will be to create a new Rule for your Handler and move it to over the default handler.
Hope this helps!
