Stange problem accepting calls on FXO
Jun 7th, 2007
Having a strange issue with an VIC2-4FXO where after a reboot on of the ports will see an incomming call, but never does anything with it. Yet, if I plug another line into that port it works as expected when called.
To get around this, I just swapped the lines, and modified the config. Everything was fine until I rebooted...it happened again.
To fix it, ive just swapped the lines around back to normal and changed the dial-peers and plar....
My debug of the problem looks like this:
Jun 8 01:50:04.241: htsp_process_event: [0/0/3, FXOGS_ONHOOK, E_DSP_SIG_0000]fxogs_onhook_ringing
Jun 8 01:50:04.241: htsp_timer_stop
Jun 8 01:50:04.241: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:04.241: htsp_timer - 125 msec
Jun 8 01:50:04.369: htsp_process_event: [0/0/3, FXOGS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxogs_wait_ring_min_timer
Jun 8 01:50:04.369: htsp_timer - 10000 msec
Jun 8 01:50:04.369: htsp_timer3 - 5600 msec
Jun 8 01:50:04.369: [0/0/3] htsp_start_caller_id_rx:BELLCORE
Jun 8 01:50:04.369: [0/0/3] htsp_dsm_create_success returns 1
Jun 8 01:50:05.337: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_0100]
Jun 8 01:50:05.337: fxogs_ringing_not:
Jun 8 01:50:05.337: htsp_timer_stop
Jun 8 01:50:05.337: htsp_timer_stop2
Jun 8 01:50:05.337: htsp_timer - 10000 msec
Jun 8 01:50:05.740: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_1100]
Jun 8 01:50:05.740: fxogs_ringing_no_tipgnd
Jun 8 01:50:05.740: htsp_timer_stop
Jun 8 01:50:05.740: htsp_timer_stop2
Jun 8 01:50:05.740: htsp_timer2 - 350 msec
Jun 8 01:50:06.100: htsp_process_event: [0/0/3, FXOGS_RINGING, E_HTSP_EVENT_TIMER2]fxogs_ringing_disc
Jun 8 01:50:06.100: [0/0/3] htsp_stop_caller_id_rx. message length 0
Jun 8 01:50:06.100: htsp_timer_stop
Jun 8 01:50:06.100: htsp_timer_stop2
Jun 8 01:50:06.100: htsp_timer_stop3
Jun 8 01:50:06.100: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:06.104: flex_dsprm_close_cleanup
Jun 8 01:50:06.104: [0/0/3] htsp_dsm_close_done
Jun 8 01:50:07.236: htsp_process_event: [0/0/3, FXOGS_ONHOOK, E_DSP_SIG_0000]fxogs_onhook_ringing
Jun 8 01:50:07.236: htsp_timer_stop
Jun 8 01:50:07.236: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:07.236: htsp_timer - 125 msec
Jun 8 01:50:07.364: htsp_process_event: [0/0/3, FXOGS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxogs_wait_ring_min_timer
Jun 8 01:50:07.364: htsp_timer - 10000 msec
Jun 8 01:50:07.364: htsp_timer3 - 5600 msec
Jun 8 01:50:07.364: [0/0/3] htsp_start_caller_id_rx:BELLCORE
Jun 8 01:50:07.364: [0/0/3] htsp_dsm_create_success returns 1
Jun 8 01:50:08.336: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_0100]
Jun 8 01:50:08.340: fxogs_ringing_not:
Jun 8 01:50:08.340: htsp_timer_stop
Jun 8 01:50:08.340: htsp_timer_stop2
Jun 8 01:50:08.340: htsp_timer - 10000 msec
Jun 8 01:50:08.740: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_1100]
Jun 8 01:50:08.740: fxogs_ringing_no_tipgnd
Jun 8 01:50:08.740: htsp_timer_stop
Jun 8 01:50:08.740: htsp_timer_stop2
Jun 8 01:50:08.740: htsp_timer2 - 350 msec
Jun 8 01:50:09.104: htsp_process_event: [0/0/3, FXOGS_RINGING, E_HTSP_EVENT_TIMER2]fxogs_ringing_disc
Jun 8 01:50:09.104: [0/0/3] htsp_stop_caller_id_rx. message length 0
paul_alexander Thu, 06/07/2007 - 22:42
Jun 8 01:50:09.104: htsp_timer_stop
Jun 8 01:50:09.104: htsp_timer_stop2
Jun 8 01:50:09.104: htsp_timer_stop3
Jun 8 01:50:09.104: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:09.108: flex_dsprm_close_cleanup
Jun 8 01:50:09.108: [0/0/3] htsp_dsm_close_done
Jun 8 01:50:10.248: htsp_process_event: [0/0/3, FXOGS_ONHOOK, E_DSP_SIG_0000]fxogs_onhook_ringing
Jun 8 01:50:10.248: htsp_timer_stop
Jun 8 01:50:10.248: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:10.248: htsp_timer - 125 msec
Jun 8 01:50:10.376: htsp_process_event: [0/0/3, FXOGS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxogs_wait_ring_min_timer
Jun 8 01:50:10.376: htsp_timer - 10000 msec
Jun 8 01:50:10.376: htsp_timer3 - 5600 msec
Jun 8 01:50:10.376: [0/0/3] htsp_start_caller_id_rx:BELLCORE
Jun 8 01:50:10.376: [0/0/3] htsp_dsm_create_success returns 1
Jun 8 01:50:11.340: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_0100]
Jun 8 01:50:11.340: fxogs_ringing_not:
Jun 8 01:50:11.340: htsp_timer_stop
Jun 8 01:50:11.340: htsp_timer_stop2
Jun 8 01:50:11.340: htsp_timer - 10000 msec
Jun 8 01:50:11.740: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_1100]
Jun 8 01:50:11.740: fxogs_ringing_no_tipgnd
Jun 8 01:50:11.740: htsp_timer_stop
Jun 8 01:50:11.740: htsp_timer_stop2
Jun 8 01:50:11.740: htsp_timer2 - 350 msec
Jun 8 01:50:12.092: htsp_process_event: [0/0/3, FXOGS_RINGING, E_HTSP_EVENT_TIMER2]fxogs_ringing_disc
Jun 8 01:50:12.092: [0/0/3] htsp_stop_caller_id_rx. message length 0
Jun 8 01:50:12.092: htsp_timer_stop
Jun 8 01:50:12.092: htsp_timer_stop2
Jun 8 01:50:12.092: htsp_timer_stop3
Jun 8 01:50:12.092: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:12.096: flex_dsprm_close_cleanup
Jun 8 01:50:12.096: [0/0/3] htsp_dsm_close_done
Jun 8 01:50:13.240: htsp_process_event: [0/0/3, FXOGS_ONHOOK, E_DSP_SIG_0000]fxogs_onhook_ringing
Jun 8 01:50:13.240: htsp_timer_stop
Jun 8 01:50:13.240: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:13.240: htsp_timer - 125 msec
Jun 8 01:50:13.368: htsp_process_event: [0/0/3, FXOGS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxogs_wait_ring_min_timer
Jun 8 01:50:13.368: htsp_timer - 10000 msec
Jun 8 01:50:13.368: htsp_timer3 - 5600 msec
Jun 8 01:50:13.368: [0/0/3] htsp_start_caller_id_rx:BELLCORE
Jun 8 01:50:13.368: [0/0/3] htsp_dsm_create_success returns 1
Jun 8 01:50:14.336: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_0100]
Jun 8 01:50:14.336: fxogs_ringing_not:
Jun 8 01:50:14.336: htsp_timer_stop
Jun 8 01:50:14.336: htsp_timer_stop2
Jun 8 01:50:14.340: htsp_timer - 10000 msec
Jun 8 01:50:14.739: htsp_process_event: [0/0/3, FXOGS_RINGING, E_DSP_SIG_1100]
Jun 8 01:50:14.739: fxogs_ringing_no_tipgnd
Jun 8 01:50:14.739: htsp_timer_stop
Jun 8 01:50:14.739: htsp_timer_stop2
Jun 8 01:50:14.739: htsp_timer2 - 350 msec
Jun 8 01:50:15.095: htsp_process_event: [0/0/3, FXOGS_RINGING, E_HTSP_EVENT_TIMER2]fxogs_ringing_disc
Jun 8 01:50:15.095: [0/0/3] htsp_stop_caller_id_rx. message length 0
Jun 8 01:50:15.095: htsp_timer_stop
Jun 8 01:50:15.095: htsp_timer_stop2
Jun 8 01:50:15.095: htsp_timer_stop3
Jun 8 01:50:15.095: TGRM: reg_invoke_tgrm_call_update(0, 0, 3, 65535, 1, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
Jun 8 01:50:15.099: flex_dsprm_close_cleanup
Jun 8 01:50:15.099: [0/0/3] htsp_dsm_close_done
paul_alexander Thu, 06/07/2007 - 22:46
voice-port 0/0/2
supervisory disconnect dualtone mid-call
cptone AU
timeouts wait-release 1
connection plar opx 811
impedance complex1
station-id name SS-Naomi
station-id number 0393842244
caller-id enable
voice-port 0/0/3
cptone AU
connection plar opx 806
impedance complex1
station-id name SS-Garden
station-id number 0393864241
caller-id enable
To be honest, ive had so many problems with these PSTN lines, but this is the only outstanding one.
What bugs me, is my configuration on the ports doesnt change. Its just the swapping of the lines that does.
